les Offline
#1 Posted : Wednesday, 27 June 2012 4:15:37 AM(UTC)
les
Can anyone confirm that the GMH Utilux hose clamps were Gold
#2 Posted : Wednesday, 27 June 2012 4:29:02 AM(UTC)
Yes & no.
I've always known the colour of that plating as yellow chromate, which has more like a 'yellowy chrome' look rather than gold. I believe this a hexavalent chromium compound & as such is now banned virtually worldwide.
I think that a lot of repro stuff these days is just too gold.
ktgelec Offline
#3 Posted : Wednesday, 27 June 2012 8:32:29 PM(UTC)
ktgelec
I agree with Terry that they would have been a hexavalent yellow chromate. Substrate was probably cadmium whereas these days you are likely to have a zinc substrate with trivalent chromate. They may use hex chromate in China which has superior corrosion resistance, however if they use cadmium substrate the goods are classed as hazardous and may be difficult or impossible to import.
You can still easily get cad plating done in Australia, and cad has superior corrosion resistance and other properties such as stick-slip.
You can produce a very close match to cad in appearance with zinc and trivalent chromate by controlling activation method and immersion time. It looks too yellow if you dip it for too long. Can also be too dull if you use HCl instead of nitric acid to activate, or if you dont start with a bright enough zinc substrate.
les Offline
#4 Posted : Thursday, 28 June 2012 3:07:20 AM(UTC)
les
Thanks guys we will go for gold and try to get it as close to original as possible
Les
domsmith Offline
#5 Posted : Sunday, 1 July 2012 5:35:57 AM(UTC)
domsmith
I think while choosing one you should also take care care of the whole mark, which is marked on only original gold items...Do don't forget to check this mark.
[url="http://www.alliance-express.com/"]plastic flanges[/url] | [url="http://www.alliance-express.com/masking-products
"]masking products[/url]
Edited by user Sunday, 1 July 2012 5:38:29 AM(UTC)  | Reason: Not specified
This page was generated in 0.118 seconds.
