1970ht Offline
#1 Posted : Friday, 29 June 2012 7:43:56 AM(UTC)
1970ht
changing the disc pads on the prem tommorow what is the best way to run them in . discs r in very good nick
#2 Posted : Friday, 29 June 2012 8:00:59 AM(UTC)
Make sure you machine the disc rotors, pads take a lot longer to bed-in if the surface is shiny or glazed.
BIGCAV Offline
#3 Posted : Saturday, 30 June 2012 4:52:15 AM(UTC)
BIGCAV
depends on what pads your using, ceramic? metalic? etc etc
if your after a good allrounder pad i like the bendix gct's (ceramics) which dont need to be bed in according to bendix, i have still done the usual bed in process a couple of times before and didnt really notice a difference between not running them in and when i fitted a set last weekend in a rush and didnt use a bedding in process
1970ht Offline
#4 Posted : Saturday, 30 June 2012 5:42:53 AM(UTC)
1970ht
Useing the IBS brand and not to sure of the exact material . Took the rotors off to get machined like dr Terry said and pick them up in the morning at abs brakes .
BIGCAV Offline
#5 Posted : Saturday, 30 June 2012 7:25:20 AM(UTC)
BIGCAV
ibs brand would require a normal run in process, a couple of medium-hard stops at 60, then a few more at 80 then a couple at 100 etc
should be able to get a bit of smoke off the pads
1970ht Offline
#6 Posted : Saturday, 30 June 2012 7:48:02 AM(UTC)
1970ht
81837 Offline
#7 Posted : Friday, 6 July 2012 3:55:50 AM(UTC)
81837
Do you have anti-squeal shims for your calipers? I machined discs and replaced pads in a HT and had terrible squealing problems from the new pads. I tried a few chemical fixes that did not work, and finally found a set of shims in a wreck that fixed the problem. Don't throw your old pads out until you are happy with the new!
1970ht Offline
#8 Posted : Saturday, 7 July 2012 2:07:20 AM(UTC)
1970ht
No I dont have the the shims . From the previous set I had bad squeeling for a couple of months but so far with these I have no probs .
