simonbee Offline
#1 Posted : Tuesday, 24 July 2012 5:13:02 AM(UTC)
simonbee
HI guys just after a some info i have a HT Monaro with the ina and outer gaurds been cut what i like to know if i can source a ina gaurd and the outer gaurd peice will it work by welding it together just finding it hard for anyone to do it for me anytips to repair it or anyone in sydney you can recomend to do the job otherwise im going to attemp it myself i found a restorer Deanmonaros will supply me cutouts from a doner car but is to busy to do the work any thoughts guys.
Bingy Offline
#2 Posted : Tuesday, 24 July 2012 8:12:07 AM(UTC)
Bingy
Can you re-write that with some punctuation in it?
Might then be able to understand what your on about!
Remember - full stops, commas, question marks.
blameyone Offline
#3 Posted : Wednesday, 25 July 2012 3:00:41 AM(UTC)
blameyone
Check the parts catalogue. You will find there are a lot of common parts with the 2 door and 4 door cars even in the inner panels......best regards....Jack
ht307munro Offline
#4 Posted : Wednesday, 25 July 2012 4:59:10 AM(UTC)
ht307munro
Mate ask Dean from Deanomoanaro - he will know exactly what you need and makes a fair few replacement sections. The inner panels on a sedan are mostly the same as a monaro so should fit. Outer quarter panel is different between monaro and sedan. Post some pictures for others to see.
Alex
