RussVRute Offline
#1 Posted : Friday, 22 April 2005 6:06:29 AM(UTC)
RussVRute
G'day All,
I'm thinking of putting a V8 into the ronner, and I know you have to change engine mounts, radiator and coil springs, but what else do I need to change, e.g. can I still use the same cross member, tailshaft and gearbox (aussie 4 speed)or do they have to be changed too? is a 4 speed box the same for a 6 and an 8? I'm not doing it just yet but I would like to know excactly what I need and do it all in one hit as it is a work vehicle and cant be off the road too long. Any advice will be appreciated.
classic oz wreck Offline
#2 Posted : Friday, 22 April 2005 6:20:25 AM(UTC)
classic oz wreck
tailshaft xmember speedo cable all the same 4 speed and trimatic...v8 4 speed has longer front shaft and bellhousing is different..if going 4 speed then depending on if car is already manual and which model bracket on side of bellhousing or cable only or
www.classicozwreck.com.au
#3 Posted : Friday, 22 April 2005 6:47:31 PM(UTC)
Coil springs will be OK. Rest as per Greg's comments. Your best bet is to find a complete car with a V8 (and preferably 4-speed) and swap it all over. When you get closer email me and I can tell you which bits and pieces you need. Greg will normally have
