LHQ-253 Offline
#1 Posted : Wednesday, 1 August 2012 8:25:07 AM(UTC)
LHQ-253
Did the T350 get fitted to any HQ-Z or WB Holdens, or was it only VB Commodores? I'm pretty sure the T400 was used from HQ to WB, and not the T350.
#2 Posted : Wednesday, 1 August 2012 5:32:32 PM(UTC)
TH350 was used from around 5/79 to late 1981, so HZ, WB, VB-VH. The TH400 was used HQ-HZ and VB.
LHQ-253 Offline
#3 Posted : Saturday, 4 August 2012 8:12:12 AM(UTC)
LHQ-253
Thanks Byron, very helpful.
Next question is whether or not the trans pipes to the radiator would be the same for a HX T400 or HZ T350?
Do they connect to the same place on the transmission housing, or are the housings different too?
#4 Posted : Saturday, 4 August 2012 6:18:35 PM(UTC)
Same pipes on HZ. HZ cattledog lists a different part number for the sockets on the 77EK transmission (which is the same as a HX) but it supercedes to the 78EK part anyway. TH350 doesn't list these as I think they are part of the transmission. In any case the pipes are the same part number for HZ TH400 and TH350.
WB are different due to the different radiator.
