asdf88 Offline
#1 Posted : Monday, 6 August 2012 3:49:46 AM(UTC)
asdf88
Hi all,
I'm reconditioning underneath my HZ GTS and I'm about to take out the petrol tank and all the fuel lines. Before I do, I need to understand how it all goes back together and what everything is for.
I can work out that the sender unit has a 'petrol out' pipe and a 'Vapour return' pipe (small diameter). I was wondering what all the other pipes are for.
There are 3 other pipes (2 on the right and 1 on the left) coming out of the tank that lead to a block. What is that block thing for?
I would really appreciate if someone has a diagram that explains it all.
Thanks, Alan.
#2 Posted : Monday, 6 August 2012 7:36:14 AM(UTC)
The 'block' is the vapour separator. A line from this goes to the carbon canister.
If your car has a 'return line' it must have factory a/cond. Does it ?
Dr Terry.
asdf88 Offline
#3 Posted : Tuesday, 7 August 2012 4:51:35 AM(UTC)
asdf88
Thanks Dr Terry, yes it has factory air. It also has a round vapour seperator and return line up near the carby as well.
Cheers, Al.
