Getmanki Offline
#1 Posted : Tuesday, 7 August 2012 3:28:58 AM(UTC)
Getmanki
airbag light just started coming on intermittently. It is almost certainly a connection since it goes off and comes on as the road gets rough.
does it happen to your Holden?
how to reset airbag?
or should i get one GM Tech2 to reset?
i found GM Tech2 at uobd2
http://link-removed.com
that is pricey
so any guidance help reset airbag??
#2 Posted : Tuesday, 7 August 2012 4:35:33 PM(UTC)
You do need the Tech2 to reset it, or the expensive snap-on or other branded workshop scan tools (talking thousands of dollars, not hundreds). There's no "cheap" scanner on the market that will do the airbags.
Be very wary of buying a supposed genuine Tech2 online. Do a google search for "Tech2 China clone" - that search string on its own should be enough to scare you, but if not, have a browse of this thread:
http://forums.corvettefo...r-clone-or-no-clone.html
What model are we talking? Some are notorious for a broken/intermittent clock spring (it's inside the column, and connects the airbag to the wiring harness, allowing the stering wheel to turn).
Getmanki Offline
#3 Posted : Tuesday, 7 August 2012 9:25:10 PM(UTC)
Getmanki
this one is china clone GM Tech2
but i saw some guidance online
it said there are a $5 APP and a $25 obd2 code scanner just can fix things down the scanner like ELM327
$30 total.. that sweet..
#4 Posted : Wednesday, 8 August 2012 4:08:18 AM(UTC)
So you're just a spammer.
I have removed the links to your spam sites.
These "china clones" simply don't work, and no, you cannot clear an airbag code with a $30 scammer oops, I mean scanner.
