airbag light just started coming on intermittently. It is almost certainly a connection since it goes off and comes on as the road gets rough. does it happen to your Holden? how to reset airbag? or should i get one GM Tech2 to reset? i found GM Tech2 at uobd2 http://link-removed.comthat is pricey so any guidance help reset airbag??
You do need the Tech2 to reset it, or the expensive snap-on or other branded workshop scan tools (talking thousands of dollars, not hundreds). There's no "cheap" scanner on the market that will do the airbags. Be very wary of buying a supposed genuine Tech2 online. Do a google search for "Tech2 China clone" - that search string on its own should be enough to scare you, but if not, have a browse of this thread: http://forums.corvettefo...r-clone-or-no-clone.htmlWhat model are we talking? Some are notorious for a broken/intermittent clock spring (it's inside the column, and connects the airbag to the wiring harness, allowing the stering wheel to turn). |
this one is china clone GM Tech2 http://link-removed.combut i saw some guidance online it said there are a $5 APP and a $25 obd2 code scanner just can fix things down the scanner like ELM327 http://link-removed.com$30 total.. that sweet..
So you're just a spammer.
I have removed the links to your spam sites.
These "china clones" simply don't work, and no, you cannot clear an airbag code with a $30 scammer oops, I mean scanner. |
