montor Offline
#1 Posted : Friday, 24 August 2012 7:21:06 AM(UTC)
montor
Hi, can anyone help, i'm interested in tunnel ramming a 327 aspirated with about 400hp and drive it as an every day car, what would be a good set of heads to put on it, at the moment i have no heads for it, cheers
#2 Posted : Friday, 24 August 2012 7:31:06 PM(UTC)
double hump fuelies.
Could go a size down 307 onto 327 my pontiac has 327 heads on a 4bolt 350 ample grunt!
#3 Posted : Friday, 24 August 2012 8:39:13 PM(UTC)
New cast iron Darts might be worth looking at too.
petaus Offline
#4 Posted : Saturday, 25 August 2012 2:42:39 AM(UTC)
petaus
I would go some new, cast iron darts or alloys depending on your budget, towoomba foundry used to make some chev heads not sure if the still do them now, fullies are o.k but they are getting hard to get a good set now so demand good money so i would buy some cast iron darts excellent value for money, really for 400hp would not need porting, drop in some new valves,spring, retainers and locks and away you go.
montor Offline
#5 Posted : Saturday, 25 August 2012 8:45:30 PM(UTC)
montor
thanks for the replies, if i was to go for the Dart heads, whats the advantage of the alloy over cast iron other than the obvious being weight? also what size intake and combustion chamber should i go for if 350 to 400hp for the street was being produced, cheers
400bowtie Offline
#6 Posted : Sunday, 26 August 2012 6:33:57 AM(UTC)
400bowtie
hi monter. The Dart iron is good (as Byron said worth looking at) but there are heavy 52 lbs much more than a chev orginal type. They have got hardened seats,stainless valves and new springs ect (not 40 year old stuff) . If you went this way you'ld have to fit hardened pushrods as they run in a guideplate, not the cast iron of the head.A 64cc chamber and 180cc intake should ark it up. Unless its modifed more a bigger port might work. Also don't dismiss new bowtie's,very good with 184cc intake. Dave
The difference between good and great is the extra effort
montor Offline
#7 Posted : Wednesday, 29 August 2012 8:22:46 AM(UTC)
montor
thanks Dave and Byron for the good advice, Bowtie or Dart will be the go then, building a couple of neat streeters with HP and using this forum as a way to gain good advice from the people that used the products rather than someone just trying to sell you something they stock, once again thanks
#8 Posted : Thursday, 30 August 2012 10:02:29 PM(UTC)
I've never used the Dart heads, but those that have have told me they are good value for money and bang for buck. I think the original Darts were copies of the last of the factory Fuellies ie 291 slant plug heads.
