Hi, how much better are the original VL Walkinshaw heads compared to the VN heads the heads would be mounted to a 355 stroker with a 6/71 on top. also are the heads on the VN Group A the same as the Walky heads, cheers
Have you considered new alloy heads? |
nah, i haven't but only because i want to rock some good horsepower out of a Holden block and heads
I'd give COME a call and ask them. The original VN-VSIII heads are pretty good standard, they handled the factory 350ci HSV engines OK. |
Thanks: 8 times Was thanked: 16 time(s) in 14 post(s)
The factory iron heads are pretty damn good for 90% of engines but with a blower im not sure the exhausts in ANY of the factory heads will let it breathe well enough to make good use of the pump.
