sixty8auto Offline
#1 Posted : Thursday, 6 September 2012 9:01:05 AM(UTC)
sixty8auto
I have removed the fuel tank and have cleaned it up with some degreaser and muscle.
What are the fuel tanks made of? It looks as though there is a little bit of surface rust.
Once cleaned up would I need to seal the exterior or..
5 Car Projects, 1 pair of hands, limited budget, 10% knowledge, can do attitude
#2 Posted : Thursday, 6 September 2012 5:47:06 PM(UTC)
Fuel tanks in those days were made of pressed steel & then zinc plated, I believe.
The plating will be very thin now. which is why it has rusted. I would clean it thoroughly & use some epoxy type paint to restore it.
sixty8auto Offline
#3 Posted : Friday, 7 September 2012 1:59:46 AM(UTC)
sixty8auto
I was thinking of using por15 rust paint as primer then some chassis black on top.
That POR is some strong stuff.
blameyone Offline
#4 Posted : Friday, 7 September 2012 4:54:08 AM(UTC)
blameyone
If you check out the POR 15 brochure you'll find they have a product specifically made for what you are doing.....best regards.....Jack
