eagleknights Offline
#1 Posted : Monday, 1 October 2012 6:15:32 AM(UTC)
eagleknights
Hi all,
My Vt runs perfectly on gas but when I go to start it
On petrol or even switch over to petrol it runs for 2 seconds
Then dies. This happens weather I'm driving at the time or not please someone help me
Figure out what's wrong and how to fix it
Tm
#2 Posted : Monday, 1 October 2012 7:17:54 AM(UTC)
Because there's a myriad of different gas systems out there, and even more installers, all of whom do things differently, it's not an easy thing to diagnose.
Start with the basics.
You obviously have spark, so that rules out ignition - leaving fuel the culprit.
Switch it to fuel, try to start it. Listen for the fuel pump priming & running. Feel the injectors to see if they are clicking.
Inspect the installation - work out where they have intercepted the loom to cut power to the injectors.
If all that sounds too hard, then you're best off taking it to a reputable mechanic (or gas guy) to look at.
edelbrock1 Offline
#3 Posted : Tuesday, 2 October 2012 4:34:00 AM(UTC)
edelbrock1
My money is on the fuel pump.
#4 Posted : Tuesday, 2 October 2012 6:05:10 AM(UTC)
+1 for the fuel pump
i spose you've left near no petrol in the tank and the pumps burnt out
#5 Posted : Tuesday, 2 October 2012 7:18:37 AM(UTC)
eagleknights
I always fill up the car when there is only a quarter
Tank left or I switch it over to gas. Thanks for the advice
Figured its injectors
Tm
