HK350_2233 Offline
#1 Posted : Thursday, 4 October 2012 8:24:04 AM(UTC)
HK350_2233
Hi all,
Just want to know if someone could help with the wiring for a hk tacho.
I know the green wire goes on the negative side of the coil but where does the other wire go to and what colour is the wire ?
Some one before me as wired it like this, green to negative side of coil, white wire to positive side of coil but my guess is that this wrong ? White has been joined under console and this wire should go to 12v ignition source ?
WAHK80737 Offline
#2 Posted : Thursday, 4 October 2012 10:11:42 AM(UTC)
WAHK80737
When I put mine (186S HK gts) in there were 4 wires from the back of the tacho
Black - earth
Brown - through firewall to negative side of coil
Pink - up under dash to rear of fuse panel #5 I think.
Grey - up under dash to rear of fuse panel #10 I think.
If you have access to the supplementary shop manual for HK there is a diagram there. Would post copy of mine but many thousands of miles away at the moment.
I saw some images on the web of replica tachos with brown, pink, grey and green wires.
Edited by user Thursday, 4 October 2012 10:24:07 AM(UTC)  | Reason: Not specified
HK350_2233 Offline
#3 Posted : Friday, 5 October 2012 4:04:08 PM(UTC)
HK350_2233
Ok thanks.
#5 is a tell tale I think, so would be ignition source ?
#4 Posted : Friday, 5 October 2012 5:39:34 PM(UTC)
pink is ignition on
grey is instrument lighting
black earth
Brown signal
