monman71 Offline
#1 Posted : Tuesday, 16 October 2012 3:51:43 AM(UTC)
monman71
I'm trying to find out when the Canadian gts rims finished , I have oct 1973 dated rims and wanting to know. I know they have a different shape and something to do with the welds. Cheers
#2 Posted : Tuesday, 16 October 2012 4:13:19 AM(UTC)
The Monaro bible says 1973, but no closer than that.
monman71 Offline
#3 Posted : Tuesday, 16 October 2012 5:21:46 AM(UTC)
monman71
Where do I find the date code? The one wheel I have that is not the oct 73, all I can find is inside the wheel centre it's self m4, a d in a circle and a x5. Cheers
D. A. Barnes Offline
#4 Posted : Sunday, 21 October 2012 4:08:58 AM(UTC)
D. A. Barnes
The Canadian wheels were phased out in 1973 and replaced with American made items that continued into early 1974. At the same time, local ROH made wheels were also fitted to cars. You have the interesting situation where two differnet wheels were fitted at the same time. It would be importnat to have all 5 wheels matching.
The date codes and application for the Canadian wheels are found around the valve stem hole on the rim. From memory, I think some codes are on the rim and the tyre must be removed to see them.
You obviously know that the imported wheels were different colours to the ROH ones.
What wheel nuts are you using to fit them?
monman71 Offline
#5 Posted : Sunday, 11 November 2012 8:29:56 AM(UTC)
monman71
I will have to get some wheel nuts, my parents HZ , which is a parts car came with the GTS wheels, are the HZ wheel nuts the same as HQ?
