goody333 Offline
#1 Posted : Wednesday, 31 October 2012 10:30:52 PM(UTC)
goody333
is ther any major dramas in rear mounting a vb-vk power steering rack compared to a manual rack
'not until all else fails read instructions!'
#2 Posted : Wednesday, 31 October 2012 11:35:42 PM(UTC)
Yes, there are !!
When a rack is rear mounted in an EH (or any early Holden) it has to be shortened considerably, otherwise the geometry will be way out, bump-steer especially.
Shortening a manual rack is fairly straightforward, but shortening a power rack is a seriously complicated & expensive job. It would reduce the steering lock markedly also.
I've seen it attempted several times, never successfully.
peter_flane Offline
#3 Posted : Thursday, 1 November 2012 8:41:45 AM(UTC)
peter_flane
There are other options.
I have seen a couple EH's with Toyota Cressida MX62 power steering boxes fitted. A couple thousand dollars of engineering and it can be done.
I have seen a few Hot Rods with MG/ Rover Electric column power assist and again it would be a couple thousand dollars of custom engineering. It could be fitted to the column and the shortened Commodore manual rack fitted.
goody333 Offline
#4 Posted : Friday, 2 November 2012 5:19:49 AM(UTC)
goody333
thanks guys not what i wanted to hear though!!!!!!!!!
HGV8 Offline
#5 Posted : Friday, 2 November 2012 9:08:59 AM(UTC)
HGV8
Was thanked: 11 time(s) in 10 post(s)
There is the option of using an original EH power steering setup but not much feel and very light. But again pricey.
j.williams
Todd64eh Offline
#6 Posted : Monday, 12 November 2012 2:37:18 AM(UTC)
Todd64eh
are there any other options to put power steer in an eh?
#7 Posted : Monday, 12 November 2012 3:58:57 AM(UTC)
There are, but it's expensive & in many cases don't work as well as what you have now. Save your $$$ for other more important parts of your 'restoration'.
Keep your steering box & linkage & just get it refurbished where necessary.
peter_flane Offline
#8 Posted : Monday, 12 November 2012 5:51:52 AM(UTC)
peter_flane
In seeing thousands of EH's, I have only seen power steering in a couple dozen, and the cost is always thousands of dollars.
