iuiw Offline
#1 Posted : Tuesday, 13 November 2012 9:05:23 AM(UTC)
iuiw
I have a steelcase Celica 5 speed gearbox I wish to install in a LJ Torana.
I have the crossmember? Can I use my Holden Flywheel? What clutch plate do I use & what pressure plate do I use.
The Celica Pressure Plate I have won't fit on the standard Holden Flywheel bolt Holes.
The Celica Clutch Plate I have won't fit inside the Holden Pressure Plate.
Any help would be good?
#2 Posted : Tuesday, 13 November 2012 4:22:28 PM(UTC)
You use a Holden flywheel & pressure plate.
Dellow can sell you a clutch plate of the correct dimensions to fit the celica input shaft, and the Holden fly/pressure combo. I have been told it's a certain model of toyota dyna that's the right size.
If the clutch plate you have is too big, it may be from a blue/black 6 conversion, or a red 253, as they had a bigger flywheel than the red 6.
