Todd64eh Offline
#1 Posted : Thursday, 22 November 2012 7:04:25 PM(UTC)
Todd64eh
I have been given a 179 block which has been sitting in a backyard for 20 years and would need at least an acid dip and cylinder hone plus full rebuild. I would bore out to a 186 if I went this way. Quote to do this is $2400 includes all parts and machining but I have to assemble the engine... My other choice, is I could buy a 186 in running order, which would probably need a simple rebuild and machine the heads. The bloke wants $200 for it. Whats best? Any suggestions?
Utility8 Offline
#2 Posted : Thursday, 22 November 2012 7:56:31 PM(UTC)
Utility8
A running 186 should last you for a while. Have you heard it run or driven it? Maybe a compression test would be a good idea.
It's not often that a motor "would probably need a simple rebuild and machine the heads".
Generally, once opened, more issues will be revealed = more cost.
Having the machining of engine parts done, & all the remaining parts handed to you for assembly, is not a job for the faint hearted. You'll also find no warranty on the motor if you assemble it yourself.
As with the question you posted about the difficulty of fitting a Celica box, a motor rebuild isn't a simple task, it really depends on the knowledge & skill set you have, along with availability of tools & equipment.
My advice would be consider the running 186 first, only if it is a confirmed good running motor. If it's good, put a new set of gaskets on it, rocker cover, side plates, sump etc., & use it. If it's no good, there are still many red motors available that are confirmed good runners, you've just gotta look. As mentioned on your other post, perhaps contact & get involved with a car club. (before you start your project). Your states EH club is probably a good start. Everything you're looking to do has been done by many guys before & you will find good info & the chance to look at the mods completed. More importantly, talk directly to guys who've done them. Learning the pitfalls, & there are many, will make your build more enjoyable.
Edited by user Thursday, 22 November 2012 11:43:27 PM(UTC)  | Reason: Not specified
utility8
#3 Posted : Friday, 23 November 2012 12:29:55 AM(UTC)
Originally posted by Utility8
As with the question you posted about the difficulty of fitting a Celica box, a motor rebuild isn't a simple task, it really depends on the knowledge & skill set you have, along with availability of tools & equipment. As mentioned on your other post, perhaps contact & get involved with a car club. (before you start your project). Your states EH club is probably a good start. Everything you're looking to do has been done by many guys before & you will find good info & the chance to look at the mods completed. More importantly, talk directly to guys who've done them. Learning the pitfalls, & there are many, will make your build more enjoyable.
BRAVO !!
Todd64eh Offline
#4 Posted : Friday, 23 November 2012 6:05:50 AM(UTC)
Todd64eh
Thanks, we have a good holden club where I live, but they meet Sundays and I work Sundays so It is very hard to be involved, but I have contacted them and they have been very helpful to date!
Premier 350 Offline
#5 Posted : Saturday, 24 November 2012 12:19:01 AM(UTC)
Premier 350
In addition to Utility8's valid points, I'd also be checking the oil pressure too.
