yarrum308 Offline
#1 Posted : Thursday, 13 December 2012 6:59:36 PM(UTC)
yarrum308
Could anyone that has a HZ wagon measure exactly where the child restrainst are for me please. I know they were originaly in the rear floor just in front of the spare wheel lift out through the steel channel but how far apart are they? how far in from edge of board are they and is there 2 or 3? I want to fit them in a HQ and want them to look factory, HQ never had them HZ did and not sure about HJ HX. I refuse to put some stupid bar accross the top of the seat like queensland transport want. Thanks
Jonesy77 Offline
#2 Posted : Wednesday, 19 December 2012 5:35:35 AM(UTC)
Jonesy77
G'day mate there should be two hole on each side,one that is 7" in from the inner wheel arch that should have a factory nut welded to the crossmember,and the second one is 8"7/8 in this is just a hole i placed a peice of 1"x1/2" flat the full lenght across and drilled and taped the hole in the exsisting holes that had no nut and spot welded the bar in strong enough to lift the car of the ground, hope this helps
Happiness is not a destination but a way of life (so drive a kingswood)
yarrum308 Offline
#3 Posted : Tuesday, 8 January 2013 11:26:47 PM(UTC)
yarrum308
Thanks, yes mine has the hole 8 7/8" in from wheel arch but not the other one with the nuts welded to it. Is there not one in the centre? sedans had 3 i wonder why wagons didnt. I was planning on doing the same thing you mentioned to spread the load, thanks again.
