Todd64eh Offline
#1 Posted : Wednesday, 26 December 2012 5:21:21 AM(UTC)
Todd64eh
Hi, I have just bought a HR front end for my EH wagon. The engine mounts were moved many years ago to fit an EJ. The mounts seem to be in the right position for my EH however they are about 15mm higher than the original EH mounts. The previous owner said it worked perfectly fine for his EJ. Does anyone know why this would be the case and if the higher mounts might cause me any issues for my EH?
Thanks for your help!
Utility8 Offline
#2 Posted : Wednesday, 26 December 2012 9:20:45 AM(UTC)
Utility8
The mounts will either be in the correct position or not. 15mm higher is 15mm higher, which ain't really "in the right position" at all.
This will increase the crank shaft angle in relation to the diff pinion angle.
Get these angles outside the acceptable range for your driveline combo & you may find vibration issues crop up.
If you're gunna do it, do it right.
As far as it "working perfectly fine in his EJ", that also depends on what height the rear crossmember sat the gearbox at. Along with knowing if the car had a factory diff &/or if it was lowered with reset springs/blocks etc.
Ensure that the mounts on the replacement HR front end will sit the motor exactly where it sat from factory. It is the only way to tackle fitting a HR front end into an EH.
utility8
Todd64eh Offline
#3 Posted : Wednesday, 26 December 2012 7:06:48 PM(UTC)
Todd64eh
Thanks, might take the mounts off the EH front end and put them on the HR just to be safe.
coupe Offline
#4 Posted : Wednesday, 26 December 2012 10:04:39 PM(UTC)
coupe
This may shed some light on the subject. I removed this front end to return to the guy I bought it off as that was part of the deal when I bought the car from him. We later did another deal on some parts and it made it back into my possession. In the mean time I fitted my own hr front end into my ej. I copied this front end exact and it works perfectly. I am running the original 3 speed column crash with the side mounts on the transmission. The car wasnt lowered at all but had the towing rear spring setup if that makes a difference. The rocker cover didnt fowl on the accelerator crossover bar at the rear of the engine nor did the draglink fowl on the sump, it was running a hr draglink. The car was driven without any problems for over 20 years as I know the history of it, it was running a worked hp engine with a x2 carby setup, hope some of this helps
Todd64eh Offline
#5 Posted : Thursday, 27 December 2012 1:23:03 AM(UTC)
Todd64eh
I think I see my mistake! Sorry guys, I assumed the EH mounts would be welded onto the HR crossmember. But I now realise the HR and EH cross members are a slightly different shape, so if the EH mounts were used it would be too low. The bolt hole position on the HR does measure the same as the EH! I'm pretty sure it's all good! Sorry for the confusion! I'm learning! :)
Thanks guys!
