#1 Posted : Sunday, 27 January 2013 11:25:02 AM(UTC)
I have to remove the fascia which goes around the single din radio on the VR. The heater is stuck on, I have replaced the heater valve but still cooks me in hot weather
The Gregorys says to lever the panel out from the bottom but it seems too stiff and I don't want to break anything.
is there a clip or something.
#2 Posted : Sunday, 27 January 2013 5:10:45 PM(UTC)
Your will need to remove the panel around the gearshift. That will give you access to the 3 screws at your panel's lower edge. It will then 'clip' out.
You may not need to remove that panel however. Have a look down a the lower RH-side of the heater case (in the footwell area). There is a small vacuum switch there which operates the heater valve, it is usually out of adjustment.
antoni Offline
#3 Posted : Monday, 28 January 2013 2:09:52 AM(UTC)
antoni
Hi is it that vaccum holds the tap in off? in VN..
I have a VN thats hot all the time. no vaccum at tap..
tony..
#4 Posted : Tuesday, 29 January 2013 11:39:46 AM(UTC)
Dr Terry thanks, had a look but couldn't find it.
now the bloody horn's not working have to make up a puller for steering wheel the horn works by direct wire but not through the button.
Edited by user Tuesday, 29 January 2013 11:43:43 AM(UTC)  | Reason: Not specified
