GTS350-4play Offline
#1 Posted : Friday, 1 February 2013 1:33:43 AM(UTC)
GTS350-4play
Hi all, Could I please get some help in getting some details on the rocker, valve, covers for the 350
Tad
Motor on now and reject ovals.
AMunro327 Offline
#2 Posted : Friday, 1 February 2013 2:05:26 AM(UTC)
AMunro327
What do you need to know?
#3 Posted : Saturday, 2 February 2013 10:25:39 AM(UTC)
GTS350-4play
Hi AMunro327
The following are some questions I have.
What are the part numbers in rocker covers? Where do they originate from? are they short or tall? and does anyone have them or where can I get them??
There was a set on ebay not long ago and they went for about $400
I believe they are corvette type 7 fin aluminum covers but that's all I know
The alternator bracket I could do with some help as well and any other info, facts and or specifics with the HQ 350 will be immense help for me.
Premier 350 Offline
#4 Posted : Saturday, 2 February 2013 10:01:02 PM(UTC)
Premier 350
AFAIK, ther rockers are a Corvette item. They should be available from the USA.
When I built my 350, I was running pwr steer, so I went for the
"high mount" alternator mount. I bought the top bracket,it bolts to
one bolt on the thermostat housing, and one on the water pump.
The bottom mount, the one the alternator pivots on is a long bolt that screws into the drivers side cyl head.The front of the bolt is supported by a bracket that bolts onto the water pump
I made a spacer for the bolt to get the correct spacing from the cyl head, and used a couple of washers as shims for final
positioning.
http://www.google.com.au...Q_AUoAA&biw=1680&bih=937
I googled "sbc high mount alternator" on google images.
There's plenty of ways to mount 'em.
And here's some rocker covers on ebay.
http://www.ebay.co.uk/it...o-sbc-chev-/261098935685
KeithA Offline
#5 Posted : Saturday, 2 February 2013 11:03:24 PM(UTC)
KeithA
On ebay there is a bloke selling cd's with the HQ parts catalogue on them. All the part numbers for any part on HQ's are in it. There is also times when the parts catalogues the dealers service departments used, selling on ebay. Two on there at the moment. I have both catalogue and cd and when I'm after a part, you retrieve the part number from the book, go to google, type something like "gm part ******, * being the part number, and it is amazing how many hits you will get. Companies still use the same part numbers today or if they have their own part number, they will usually have the original number with it.
Regarding the rocker covers, you can purchase them off ebay, bit expensive though, swap meets which is a better place to buy as you can look at them, or buy them from the states new. You can also buy the rubber grommets in the cover, alloy sticker which goes into the circle on the cover, rubber oil caps. Google does hold alot of your answers.
#6 Posted : Sunday, 3 February 2013 12:22:02 AM(UTC)
GTS350-4play
Thanks so much guys
The replies about the mounting solutions and the directions to where to look have given me a good start point to follow through on.
I have seen a few LT1 corvette and camaro rocker covers on ebay from the US that look similar but with varying part numbers. I'll also need a heap of other part numbers as well, so those cd's will be a good guide.
Thanks again for the help.
#7 Posted : Sunday, 3 February 2013 8:59:09 AM(UTC)
positioning.
look out...a new guru has arrived, defo 4xxxx time
#8 Posted : Sunday, 3 February 2013 10:02:12 AM(UTC)
GTS350-4play
Yep we all know why there's XXXX on the can, glad there some bog roll handy.
It's good to have varied opinions and a different approach. Even from a 16 year old or someone from Italy.
This page was generated in 0.109 seconds.
