74p5ltd Offline
#1 Posted : Saturday, 23 February 2013 6:08:29 PM(UTC)
74p5ltd
Was wondering if anyone can help me with some tyre sizes
for the rear of a p5 1974 LTD?
Im going to have the back rims widend from a 15x6 to a 15x8
the car has been lowered couple of inches.
I want a tyre thats going to fill up those rear guards but not
cause any rubbing scrapping issues.
If anyone coul help that would be great
Paul351xb Offline
#2 Posted : Wednesday, 27 February 2013 8:58:29 AM(UTC)
Paul351xb
Depends a bit on your wheel offset. I'd try 245s and see what you think. I know 265/14s would squeeze under with a slight inner lip shave. Not sure about 15s.
74p5ltd Offline
#3 Posted : Wednesday, 27 February 2013 11:11:22 PM(UTC)
74p5ltd
Thanks for answering, much appreciated
Well offset is standard, these are factory 15x6 when they get widend the centre staying same, im not doing a deep dish, im going to have hub caps on the car, i might look at the 245s
Edited by user Wednesday, 27 February 2013 11:12:47 PM(UTC)  | Reason: Not specified
302Superbird Offline
#4 Posted : Thursday, 28 February 2013 8:15:44 AM(UTC)
302Superbird
I would say that a 225 60 15 should fit on an 8 inch rim, and would look wide enough for the wheel arch, and should be cheaper and easier to find? Just my 2 cents worth.
79fairlane Offline
#5 Posted : Friday, 1 March 2013 11:01:25 AM(UTC)
79fairlane
as long as your rim offset is right, you should fit a 265/60/15 no probems at all. ive got 245/60/15's on the rear of my ZH and they fit with a good 15-20mm to the inside of the guards on either side of the tyre. No problems with lowering hte car either, you can only see about 10mm of tyre on mine between the rim and the guard.
regards,
Nathan
76 ZH Marquis
79 P6 LTD Town Car
01 XR8
74p5ltd Offline
#6 Posted : Saturday, 2 March 2013 7:39:36 AM(UTC)
74p5ltd
Ok sounds good, any chance you could put up a pick of the back wheel and wheel arch?
