Mr Sir Offline
#1 Posted : Monday, 18 March 2013 6:26:55 AM(UTC)
Mr Sir
Hi All, I would like to know if there is a left and a right hand side head. I took mine off to get the valve seats done but did not mark them as LHS /RHS and was told by somebody along the way that there was a left and right hand side head and to make sure my head gaskets are orientated correctly so as not to block off a small water port and to also use some sort of thread sealant (perma- blue??) on some of the bolts. Is this all correct? cheers MS
antoni Offline
#2 Posted : Monday, 18 March 2013 6:55:56 AM(UTC)
antoni
Hi
They are the same ...
Tony.
#3 Posted : Monday, 18 March 2013 7:44:34 AM(UTC)
The heads are the same, but the head gaskets have a front & rear.
Also do not put any thread sealant on the top 2 head bolts, the ones closest to the valley, otherwise you will crank the block where the threads are.
