HGV8 Offline
#1 Posted : Monday, 22 July 2013 8:57:53 AM(UTC)
HGV8
Was thanked: 11 time(s) in 10 post(s)
Could someone tell me the width of Late HG discs rotors and early HG discs ?
Thanks in advance
j.williams
#2 Posted : Monday, 22 July 2013 3:09:57 PM(UTC)
Have a look on the DBA website, there is a big .pdf file with all the disc specs.
All HG discs should be the same, they are the same as HT GTS350. Only HK and HT except GTS350 are thinner as far as I am aware.
#3 Posted : Monday, 22 July 2013 6:20:23 PM(UTC)
The DBA site has it slightly incorrect.
The disc rotor thickness for HK/T/G is as follows.
All HK :- 0.5-inch (12.7 mm)
HT except GTS 350:- 0.5-inch (12.7 mm)
HT GTS 350:- 0.625-inch (15.875 mm)
All HG:- 0.625-inch (15.875 mm)
