Memyselfmyshadow Offline
#1 Posted : Thursday, 1 August 2013 7:36:08 PM(UTC)
Memyselfmyshadow
Hi I have changed the sender & gage but still not reading the right amount of fuel on the gage to what is in the tank
AMunro327 Offline
#2 Posted : Friday, 2 August 2013 2:20:08 AM(UTC)
AMunro327
Have you had the dash out? From memory, there's an earth wire in behind the dash somewhere. If that's not connected, you'll get wrong readings.
hk307 Offline
#3 Posted : Saturday, 3 August 2013 6:34:31 AM(UTC)
hk307
it may be best to test the sender out of tank connected to the wiring with a person watching the dash gauge as it is moved thru its range.
hk307 Offline
#4 Posted : Saturday, 3 August 2013 1:10:02 PM(UTC)
hk307
