52abel Offline
#1 Posted : Tuesday, 20 August 2013 3:38:29 AM(UTC)
52abel
Hi All
I have a 77HZ premier with a two speed wiper. My problem is that when I turn on the wipers (doesn't matter what speed) the blades are really slow. Is my motor on the way out and should I replace it or is there an easy fix for this problem.
Andy
Premier 350 Offline
#2 Posted : Tuesday, 20 August 2013 5:13:22 PM(UTC)
Premier 350
I'd be checking the voltage at the wiper motor- both runnning & off.
I'd also suggest disconnecting the motor from the wiper linkage, check that the linkage is not stiff- I'm thinking a lack of lube on the wiper pivots is a possibility.
