#1 Posted : Saturday, 7 May 2005 6:41:27 AM(UTC)
Byron or anyone technically minded with electronics , I have a electronic dizzy with the coil in the cap , it was fine until the module died ( 8 years old ) a new module was put in 12 months ago and the other day while driving it stopped again , The RAA guy said it had no spark , so I took it to the workshop that fitted it ( reliable shop I have known for 10 years )and the unit tested fine on their machine and gave spark , I fitted it back in the van and no spark ?
While the unit was out I retro fitted a points system which ran okay.
Any ideas what else might be wrong with the dizzy ??
#2 Posted : Saturday, 7 May 2005 7:55:44 AM(UTC)
While I don't know the answer to your specific question Cloudy, you can easily do a few basic checks yourself.
Check for broken (or breaking) wires, dry solder joints (wiggle wires around and check for continuity appearing/disappearing), check any eart
#3 Posted : Saturday, 7 May 2005 11:02:01 AM(UTC)
Qute is on the right track over 80% of these type of module failures is due to overheating and if it has no spark at all it probably is the module, even if it tests ok on the bench
#4 Posted : Saturday, 7 May 2005 4:51:54 PM(UTC)
they heated the module up to barely touchable and it still sparked (on bench)and repacked in the heat protecting grease.
Any idea what a HEI is worth from a blue or black V8 might be an option !
#5 Posted : Sunday, 8 May 2005 12:06:42 PM(UTC)
I have seen blue/black dizzies go for anywhere between $50 and $250.
Make sure it isn't the wiring first, mate. I'd hate to see you spend a couple of hundred (or whatever) only to have the same problem because it is a crook joint or broken wire in your
#6 Posted : Monday, 9 May 2005 2:42:48 AM(UTC)
I have connected the same wires to a points dizzy and it starts the car which is why I don`t think its the wires.
Taz2 Offline
#7 Posted : Monday, 9 May 2005 3:26:05 PM(UTC)
Taz2
Try Engine Shed in Pakenham Melb. They sell, service & build up "coil in cap" distributors for 253/308's.
They may be able to diagnose your problem or possible cause over the phone.
In thrust we trust
This page was generated in 0.065 seconds.
