HR235 Offline
#1 Posted : Tuesday, 21 January 2014 5:27:31 AM(UTC)
HR235
Hi All, Have recently bought an HR Premier sedan and am seeking help to clarify i.d. tags. They are:
HR235AR-46080M
Trim: 1204-F42
Paint: 587-1703
Insert: 122
Top: D 585-9562
Firewall Stamp: HR48684M M
Firewall Small Metal Tag: M 120666
Engine No. 186A171006
I know most of it I think but may as well ask those with the knowledge.
Thanks in advance for your help.
#2 Posted : Tuesday, 21 January 2014 7:31:04 PM(UTC)
I believe the 122 code means 186, powerglide and front discs. Possibly also means sedan but not 100% sure if a wagon with the same mechanical specification used the same code or not.
#3 Posted : Tuesday, 21 January 2014 7:33:35 PM(UTC)
HR235AR-46080M (HR Premier wagon automatic RHD - 46080th HR from Melbourne vehicle assembly plant)
Trim: 1204-F42 (Grecian White over Savonna Bronze - Honey fawn with Bucket seats)
Paint: 587-1703 (Savonna Bronze
Insert: 122 (186 auto)
Top: D 585-9562 (Grecian White
Firewall Stamp: HR48684M M (HR 48684th body from Melbourne body plant)
Engine No. 186A171006 (HR 186 engine number 170006)
Warren
HR235 Offline
#4 Posted : Wednesday, 22 January 2014 4:18:03 AM(UTC)
HR235
Thanks for that, but, Warren doesn't 235 mean sedan and 239 mean wagon?
Also, does that mean the engine numbers started at 1000? Are you able to say that this engine number looks about right for the original engine as I don't have the original purchase receipt/service booklet.
Do you know what the Small Metal Tag on the firewall means: M 120666?
It has the X2 or 186S multiple gauge in it. Could this have been optioned or has someone just put it in?
Anyway of dating the car? As far as I know it is a 67 model.
Thanks again for your help and knowledge.
#5 Posted : Wednesday, 22 January 2014 5:17:15 AM(UTC)
It is a Premier Sedan, Warren has had a brain fart, we all do it!
Engine numbers started at 1001, so yours is actually the 170005th HR engine.
As far as I am aware the M120666 is the early version of the PSN (I think called plant sequence number or serial number or words to that affect). This should be the 120666th vehicle assembled at the Dandenong assembly plant since a certain date. Warren or Dr Terry will have more knowledge on this.
#6 Posted : Wednesday, 22 January 2014 5:27:49 AM(UTC)
Yes as Byron siad, brian fart.
the enigne is the 17006th, 1001 is the first enigne, so 1002 is second etc. Common error to remove 1001 when you need to remove 1000.
The car is NOT an X2 or 186S, and AFAIK the dash is not aseperate itme. Do not have enough to know if engine is right for this car
Warren
#7 Posted : Wednesday, 22 January 2014 5:49:34 AM(UTC)
The X2 instrument cluster was available for HD & HR as a factory option, PO number 580 (imperial units) or 581 (metric units).
It was also available a Nasco accessory kit (7429681 - imperial units) where they could be dealer-fitted at the time of sale or fitted by anybody after that time.
HR235 Offline
#8 Posted : Thursday, 23 January 2014 4:27:40 AM(UTC)
HR235
Thanks everyone for your information. No doubt I will call on your help again in the future.
cus Offline
#9 Posted : Tuesday, 4 February 2014 5:03:07 AM(UTC)
cus
hi guys as im new here as well i thought i would tack in on the end of this post. ive just bought a hr which im pretty sure is a standard. colour is white but im a bit stumped on the trim. it has blue door skins but i cant find the exact colour for it to chase seats. if any of you could explain the numbers that would be great
body hr 215-2118-a
trim 510-e44
paint 585-9562
it also has the d stamped at the start of top and going on other posts i assume it had some extras added at some stage
cheers cus
#10 Posted : Tuesday, 4 February 2014 8:58:59 AM(UTC)
It is an Adelaide built HR Standard sedan painted Grecian White.
The interior trim is single tone Dover Blue.
