coupe Offline
#1 Posted : Sunday, 26 January 2014 10:20:34 PM(UTC)
coupe
I'm looking for a hk chev radiator. My question is are they the same as 308 or even the later model hq-wb chev or 308, toowoomba swap next weekend so I just wanna know for sure,thanks
#2 Posted : Monday, 27 January 2014 6:30:29 AM(UTC)
308 has the outlets on the wrong side for a Chev.
Chev have the same side for top and bottom hoses same as Holden 6.
Warren
coupe Offline
#3 Posted : Monday, 27 January 2014 6:57:45 AM(UTC)
coupe
Thanks Warren, now just to find one!
#4 Posted : Monday, 27 January 2014 6:31:27 PM(UTC)
Do you want original?
coupe Offline
#5 Posted : Monday, 27 January 2014 6:57:54 PM(UTC)
coupe
Original would be great if I can find one but I wont rule out other options, do you have something, I've been looking a pwr ones that look semi original but I dont know the price yet, also do you have anything else of use to me for the chev conversion that you may want to part with?
#6 Posted : Tuesday, 28 January 2014 12:20:09 AM(UTC)
I was going to suggest finding a HJ-HZ 6cyl with A/C radiator and getting it recored and modified. Need outlets changed for larger ones and sides modified (holes only) to fit a HK. The radiator i'm referring to is often called a "3 row", same as a 308 with A/C but outlets on opposite sides. It is't original but will cool a 307 or 327 OK. You can get a 4 row core for them for a 350.
ht307munro Offline
#7 Posted : Tuesday, 28 January 2014 5:20:44 AM(UTC)
ht307munro
I am also looking for a radiator for my HT / Chev and from my research the HQ and later radiators have a small "step" where they mount where as the HK HT are flat. Is that correct? If so has anyone had any experience fitting one? I have an original HK Chev one but I got a price to have it recored and I nearly had a coronary.
Alex
