Todd64eh Offline
#1 Posted : Sunday, 23 February 2014 1:03:19 AM(UTC)
Todd64eh
So I have put a hr disc front end into my eh wagon. I have put hr slave cylinders on the rear with hr shoes. I have also put a hr disc master cylinder on the firewall. Brakes are running through a vh40 booster. Booster, cylinders all brand new. I have bleed the system starting with master cylinder, then booster, then rears then fronts. Brakes build up pressure/pedal just fine and hold pressure fine. But as soon as you release the pedal, wait two seconds, the pedal will go straight to the floor again. I cannot find any leaks in the lines. Why does the brake pedal keep going to floor? I have bleed the whole system five to six times!
coupe Offline
#2 Posted : Sunday, 23 February 2014 7:14:03 PM(UTC)
coupe
Are the rear shoes adjusted properly, just skimming as you turn the wheel? And are they hr disk brake rear wheel cylinders not drum?
Edited by user Sunday, 23 February 2014 7:15:04 PM(UTC)  | Reason: Not specified
Todd64eh Offline
#3 Posted : Monday, 24 February 2014 2:48:44 AM(UTC)
Todd64eh
Yeah, brake shoes are adjusted correctly. Yeah they are hr disc cylinders with hr shoes...Since yesterday I pulled off the front calipers, they looked seized, so I will rebuild the calipers and try again. Thanks for replying
