splitpin69 Offline
#1 Posted : Monday, 3 March 2014 3:15:30 AM(UTC)
splitpin69
Hi all, my two HT Grille badges have two different part numbers and one has two slotted dome headed bolts passing through it, centered vertically, holding the two parts together, part no/2805404-203. The other has the usual pins holding it all together no/2805404-382-1.
Am I correct in assuming that the 2 bolt job is the earlier one belonging to my 1969 model? and the other off my 1970 model?
It dosent really matter just curious is all
gunna be a long time staring at the lid of a box.....
les Offline
#2 Posted : Monday, 3 March 2014 5:15:24 AM(UTC)
les
not sure what happened to my post but what the tour director said is correct
Edited by user Monday, 3 March 2014 8:38:42 AM(UTC)  | Reason: Not specified
Tour Director Offline
#3 Posted : Monday, 3 March 2014 6:09:47 AM(UTC)
Tour Director
As the two badges both have the same part number 2805404 then the question is do they look identical. If you have a photo of the two it would be helpful.The numbers 203 & 382-1 indicate it probably came from two different suppliers. Up until the Commodores started it was common for GMH to have a couple of suppliers due to distance and manufacturing capabilities.
splitpin69 Offline
#4 Posted : Monday, 3 March 2014 6:30:57 AM(UTC)
splitpin69
Badges are identical, even down to the faded away red. Only difference is the joining bolts/pins.
