Huddo Offline
#1 Posted : Friday, 21 March 2014 5:46:57 PM(UTC)
Huddo
I am installing a LS2 - 6L80E and the original HSV dash cluster into a WB Tonner and have 3 questions. All the wiring is supplied for both engine and trans.
- Question 1 is can I just connect the dash cluster using the OEM cable and will all the management system including the driver information readout work as original.
- Question 2 what is the best radiator and cooling fan set up. The engine will end up at about 380kw. Adapt a the VE original to suit the WB or the other way WB radiator and adapt to engine.
- Question 3 will the trans fit and clear the tunnel or will it need chopping.
Thank you.
Regards,
Gus
