hk307 Offline
#1 Posted : Monday, 24 March 2014 12:05:05 AM(UTC)
hk307
Hi
nearly up to the body assembly on a log term HK 307 manual GTS� It is being done with visible originality as much as possible. Anyway the subject of the black spray on sound deadener��and would it be on inner area of rear beaver? Most areas are still obvious. The roof is still covered mostly with black spray on and i was wondering if fitting the aluminised� rubberised silver stuff over the roof inside area would help to keep out heat and a bit of noise? (Would it fall off?) Is this stuff good enough in helping NVH and heat within the cabin generally? so should it go over all the floor as well? I love the sound of driving these cars but thinking long term use.. And the paint, should it be 2 pack? colour is silver mink. I think it is too shiny what is the opinion out there?
