adam PERTH Offline
#1 Posted : Thursday, 24 April 2014 7:31:25 AM(UTC)
adam PERTH
hi, I have got a VS with Injector voltage monitor fault code 57..
the car does not run on petrol, and only on gas.
I cleared to code but it stays the same..
so what do I do to fix?
thanks in advance
#2 Posted : Thursday, 24 April 2014 5:41:55 PM(UTC)
What type of LPG system is it ? Injection, vapour, factory, aftermarket ??
That particular fault code is common on LPG cars, depending on how they're wired. With older systems, when you switch from petrol to LPG, the +ve 12V supply is cut to prevent petrol injection, this alone will trigger the code.
I would get a sparky or LPG guy to check it out. I doubt that it will be very involved.
