Shearer Offline
#1 Posted : Sunday, 4 May 2014 11:01:22 PM(UTC)
Shearer
My front window (both left and right) squeak when 10mm front the top before they close. I've put graphite power in the runners and pulled the inside trim to look for anything loose but the noise still persists.
Does anyone know what could be causing this squeak?
crowe Offline
#2 Posted : Monday, 5 May 2014 2:40:06 AM(UTC)
crowe
door runner's have an lower bolt to fix/ hold the runner frame. over time with door being closed the slide slowly moves out of alignment. loosen it off and let the glass move up and down a few times. re-tighten the bolt. now the glass should move in its proper ark. With power windows you always hear more motor strain on the last movement towards the top.
This page was generated in 0.017 seconds.
