009pk Offline
#1 Posted : Monday, 14 July 2014 6:41:10 AM(UTC)
009pk
When fitting a vn 5 litre to a vk kframe can I still use the vk pore steering rack or do I need something different
#2 Posted : Monday, 14 July 2014 6:49:56 AM(UTC)
Commodorenut is your best bet to answer this. I think he recomends using a VN or possible later member and rack.
#3 Posted : Thursday, 17 July 2014 7:45:51 PM(UTC)
Yes, VL-VS V8 K-frame (all the same as each other, but different to L6 & V6).
VN or early VP power steering rack with a splined pinion shaft (not square). V6 or V8 doesn't matter.
VL power steer intermediate shaft (links the rack to the column).
VN power steering pump & lines (hopefully sourced with the donor engine).
This is the only way you'll get enough clearance for the exhaust.
