#1 Posted : Thursday, 12 May 2005 3:28:44 AM(UTC)
G'Day all,
Seeking pro's and con's, red vrs's blue/black cylinder heads, for modification suit speedway sprintcar. I envisage a fairly seriously modified head whichever way it goes. My intention is to run triple SU's. I am trying to bring myself back up to speed with current thinking on these darling old irons.
Trick question: has anyone ever heard of, seen, had made, attempted to make, modified, etc. a cross flow head on a holden red, straight six??
Edited by user Thursday, 12 May 2005 7:11:30 AM(UTC)  | Reason: Not specified
#2 Posted : Thursday, 12 May 2005 4:01:03 AM(UTC)
Repco did these for the old grey motor. If you want a cross flow it'd probably be cheaper to run a TE/TF Cortina which had a crossflow head as standard.
If you're using a single or triple carbs (apart from dual choke triples) you are not much better of
#3 Posted : Tuesday, 17 May 2005 8:50:16 PM(UTC)
if your planning to use SU's then you will need to use a red head as thats what the manifolds suite!
#4 Posted : Wednesday, 18 May 2005 2:05:55 AM(UTC)
http://www.cdpautomachin.../leo/cylinder_head.html
Here is a dude that wanted a x-flo head for his chev straight 6. He cut the end chamber from 2 V8 heads and welded the rest together.... 1 X-Flow Head to suit a 6.
Wonder if that would work with a
#5 Posted : Wednesday, 18 May 2005 3:15:20 AM(UTC)
For the ultimate Red 6 head go here: http://www.racetech.com.au/jzed.htm
Cheers...Dave
#6 Posted : Wednesday, 18 May 2005 5:15:23 AM(UTC)
Cheers...Dave
#7 Posted : Wednesday, 18 May 2005 5:20:49 AM(UTC)
Originally posted by NBFRS
http://www.cdpautomachine.com/leo/cylinder_head.html
