dominik Offline
#1 Posted : Thursday, 7 August 2014 4:02:00 AM(UTC)
dominik
Hi
- I want to ask what type of key i need it to open the tank with oil under the engine to change to engine oil ?
- Where is the engine filter in this car because i will change it with the oil engine.
- Its that right that about every 10,000 km i have to do the overview in one of worhshop with changing engine oil is is better or maybe do it alone ?
Thanks ,stiV
castellan Offline
#2 Posted : Saturday, 9 August 2014 7:27:32 AM(UTC)
castellan
I do not know the astra engine but it may have a special key with 5 or 7 sides, just ask at Repco etc for the one you need and she may have one for the filter as well.
It may not have a sump plug as some run a hose down the dipstick tube to suck out the oil.
What ever the book says you have to do, just do it as it says.
#3 Posted : Saturday, 9 August 2014 7:23:17 PM(UTC)
The TS Astra oil filter, on some engines, is contained in an alloy canister mounted on the front of the engine & accessible from the top. It has a large hexagon on its lid, which you just undo with a spanner or socket.
The sump from memory requires a T45 Torx bit. These are a 6-pointed star, similar to a Allen key.
