While im working out what my hk was originally i may as well do the ht as well.
Theres only 2 tags so im hoping its an early one
Body tag 80437m-01192b
Skinny tag 80437th etc
Sure its a v8, the body tag number is pretty low so hoping its 2 tag car
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
It is a V8 manual HT Monaro. Most likely a 253 3spd (close ratio in HT), but could also be 253 M21 (4spd).
It is early, so will be 1969. Get me the rest of the ID (by PM if you like) and i'll find out how early.
Edit - I remove the 307 auto comment, as it can't be one of those. |
Is there an email i can reach you on, cant seem to pm
holden eat monaroparts dtod com (replace the obvious bits) |
