Brotton1 Offline
#1 Posted : Tuesday, 14 October 2014 9:48:34 AM(UTC)
Brotton1
Hi all, just need a bit of advice. Im rebuilding a HR disc brake front end for my EH. I have changed the outrigger and have noticed the HR engine mount towers are significantly higher than the EH ones. Which ones do I use when repositioning? Cheers
Edited by user Tuesday, 14 October 2014 10:43:18 AM(UTC)  | Reason: Not specified
peter_flane Offline
#2 Posted : Wednesday, 15 October 2014 4:16:30 AM(UTC)
peter_flane
You need to make a template of the position of where the EH mounts are in relation to the four main bolt holes to the chassis. Then cut and move the HR ones to be in the same position as the EH ones were. The front outrigger also has to be cut off the HR front end, and the EH outrigger put on.
