Drewyz Offline
#1 Posted : Tuesday, 21 October 2014 6:53:16 AM(UTC)
Drewyz
Gidday All
Hope I've posted this in the right location. I'm having a issue with installing a Gilmer Kit into a Vk 308 with power steering.
Firstly the P/S pulley attached to the crank pulley did not line up with P/S Pump Pulley so I made some spacers to line it up which sorted that but now the P/S belt is going to rub against the Gilmer belt, not ideal.
So a little lost as to how about going to fix the situation? Can I purchase a smaller Pump pulley, also I had heard maybe a 304 or HQ P/S bracket can be used to drop the P/S Pump unit lower.
Has anyone had a similar issue with a easy solution?
Live Life for the Moment
