redwun Offline
#1 Posted : Tuesday, 6 January 2015 10:20:21 PM(UTC)
redwun
HI,
I was wondering if someone could help me out, i have a issue with my handbrake,when i apply the handbrake and than release it, the front cable doesn't retrack and come off the front roller guide.
I have had it out looks ok and checked the middle section out all looks good, the handbrake unit seen to works ok.
Regards
Mike
peter_flane Offline
#2 Posted : Friday, 9 January 2015 9:01:35 AM(UTC)
peter_flane
Maybe the roller guide is seized. Maybe the rear diff outer cable sheath is seized. Maybe the rear brake shoes are seized. If every cable, roller and spring is working, the EH handbrake is ok. You have to check everything, not just what you can see.
redwun Offline
#3 Posted : Friday, 9 January 2015 4:18:45 PM(UTC)
redwun
i will thanks
