blameyone Offline
#1 Posted : Friday, 9 January 2015 11:28:29 AM(UTC)
blameyone
Were all front suspension X members date stamped. The recent discussion here on stencils prompted me to check the date stamp on a HK front end I have. The part number 7434500 AC stencilled on it is clearly visible, but there is no date stamped into the side of the extension. Is this unusual.
Jack
gm5735 Offline
#2 Posted : Friday, 9 January 2015 11:41:36 AM(UTC)
gm5735
I've got one of each, (stamped and unstamped) so definitely not always. It isn't always easy to see, depending on the enthusiasm of the man with the hammer.
blameyone Offline
#3 Posted : Saturday, 10 January 2015 5:50:16 AM(UTC)
blameyone
There's certainly not one on this X member, at least in the usual place you would most likely find it. Have these stamps always been put in this position. Interesting you mention the man with the hammer. Another X member I have has been stamped twice. The second time , same numbers and letter, was about the width of the digits sideways and couple mm higher than the 1st. Which makes it look almost like the one stamping .When I 1st looked for it quite a few years back now I was a bit puzzled and not till I cleaned the area up a bit did it became obvious what had happened. How often would these sort of things happen on the assembly line ?
Maybe we should start a post and call it; ' That's Peculiar ' we could all relate the peculiar things we've come across on cars. Just a thought.
Jack
#4 Posted : Saturday, 10 January 2015 8:26:20 AM(UTC)
We bought a Honda farm bike years ago. usec oil from day one. Pulled it down. Missing a scraper ring from the factory. That's peculiar. For a Honda anyway.
Gerard Offline
#5 Posted : Saturday, 10 January 2015 8:54:52 AM(UTC)
Gerard
Had a look at the cross member from my car, didn't notice a date stamp on it but toward the front l.h. side of the outrigger it is stamped at an angle with numerals and letters. A part number maybe?
gm5735 Offline
#6 Posted : Saturday, 10 January 2015 9:51:43 PM(UTC)
gm5735
The "Man with a hammer' comment was perhaps a little tongue in cheek. The larger stampings I've seen, like the cross members, firewalls etc, seem to be a little too consistent in depth to be done with a hand punch set. They are more likely to be done in some kind of press. Your double stamped item might be a double hit in the press on the way in or out.
Gerard, the letters and numbers probably are the date stamp, as it sounds like its in the right place for one. I'm not sure if you know how it works, but the first one or two numbers are the day of the month, followed by a letter, which is the month, followed by a number which will be the year. For the month, the letter "I" is not used the avoid confusion with the number 1, so the letter M will be the month of December.
For example, 5J9 would be the 5th of September 1969, and 16M0 would be the 16th of December 1970. It's also common to find other letters after the year numeral, although I'm not sure of their significance.
You will find a similar system used on castings, and also often a clock face to indicate the time of day of the casting.
Castings of American origin also reverse the day of the month and the month, so 5J9 would become J59, for example.
Gerard Offline
#7 Posted : Sunday, 11 January 2015 5:12:10 AM(UTC)
Gerard
Thanks for this info. In the case of this crossmember marked 13B9D this would translate to 13 Feb 69.
Had a look at the jack and one of the original rims and they are both stamped 12 68, I am fairly certian that this jack is original to this car as well.
Edited by user Sunday, 11 January 2015 5:21:24 AM(UTC)  | Reason: Not specified
