coupe Offline
#1 Posted : Sunday, 25 January 2015 9:08:22 PM(UTC)
coupe
Just a question regarding my hk 10 bolt. One of the axles has an end on it that is flat with 3 holes in it in a line directly through the centre, the out side ones look about 7/16 and the centre one a little smaller. The other axle end looks just like a banjo axle end with the two cast tabs coming to the centre from the outside rim. Is the flat ended one with the holes a replacement?
#2 Posted : Sunday, 25 January 2015 10:46:14 PM(UTC)
The axle with the 3 holes in a line sounds like an old 9-inch Ford axle. Both have 28 splines.
