sgo Offline
#1 Posted : Monday, 26 January 2015 6:48:21 AM(UTC)
sgo
Is it possible to get a new big nut for a big nut master cylinder ?
gm5735 Offline
#2 Posted : Monday, 26 January 2015 10:04:33 AM(UTC)
gm5735
Yes. Holdenman Restomotive on FleaBay, or his website, www.earlyholdenparts.com.au
I think there are several different types depending on which model master cylinder.
gm5735 Offline
#3 Posted : Monday, 26 January 2015 10:16:30 AM(UTC)
gm5735
It might be worthwhile comparing notes sometime. My engine number is only 9 different to yours.
sgo Offline
#4 Posted : Monday, 26 January 2015 9:21:52 PM(UTC)
sgo
Thanks for the info.
How do you know my engine number?
gm5735 Offline
#5 Posted : Tuesday, 27 January 2015 4:08:10 AM(UTC)
gm5735
You posted it some time ago. It was close to mine, so got my attention. Mines a September '69 Verdoro green Dandenong HT.
Cocko750 Offline
#6 Posted : Tuesday, 27 January 2015 4:49:00 AM(UTC)
Cocko750
Is there anything you can change on a drum brake master cyl to make it work for disc?
antoni Offline
#7 Posted : Tuesday, 27 January 2015 7:17:34 AM(UTC)
antoni
Hi yes pull out the check valve. its behind the port seat.
Tony
sgo Offline
#8 Posted : Wednesday, 28 January 2015 5:00:39 AM(UTC)
sgo
Hi gm5735, would be good to compare notes.
My address: sgomachen(at)hotmail(dot)com
Cheers .
This page was generated in 0.118 seconds.
