David 67HR Offline
#1 Posted : Monday, 2 March 2015 9:00:46 PM(UTC)
David 67HR
Can someone tell me the exact engine mount location for HR Ute please
Edited by user Monday, 2 March 2015 9:01:25 PM(UTC)  | Reason: Not specified
#2 Posted : Monday, 2 March 2015 9:23:29 PM(UTC)
Could you elaborate. The ute is no different to sedan, wagon or van.
There are 3 mounts, one each side of the engine & another at the rear of the gearbox. Do you need more info, like the exact position of bolts & washers etc. ?
David 67HR Offline
#3 Posted : Monday, 2 March 2015 10:26:57 PM(UTC)
David 67HR
Hello DR Terry, I am fitting a Rod Tech front end to my HR Ute and will be running a 383 SBC so I need to know the exact position that the mounts need to be welded onto the Front End, in the standard HR position
Edited by user Tuesday, 3 March 2015 1:15:21 AM(UTC)  | Reason: Not specified
#4 Posted : Tuesday, 3 March 2015 1:56:16 AM(UTC)
You need to get a stock front suspension x-member & measure the relative position of the original mounts to the 4 thru bolts to the chassis rail.
#5 Posted : Tuesday, 3 March 2015 2:32:58 AM(UTC)
Before you buy the Rod-tech one look at the Southern Chassis Works unit. This is what i'm going top get for my HK, they have the jigs to weld the mounts in the original place and they can make them at standard ride height.
David 67HR Offline
#6 Posted : Tuesday, 3 March 2015 11:03:38 PM(UTC)
David 67HR
Already paid deposit and getting Rod Tech front for Ute
Utility8 Offline
#7 Posted : Wednesday, 4 March 2015 8:19:47 AM(UTC)
Utility8
Too many variables to simply nominate a position in mid air to position mounts for a Chev into a HR regardless of front end. You'll need to dummy up your motor, trans etc to get correct crankshaft angle for your particular application. Then have mounts welded in correctly. Or, call Rod & have him position prior to delivery.
Edited by user Wednesday, 4 March 2015 8:21:16 AM(UTC)  | Reason: Not specified
utility8
