Fastlane
Holden Forums
Holden Technical Talk
HR 290mm Hopstop upgrade and Weld Wheels
Hi
Im looking at buying Hopper Stoppers 290mm brake upgrade kit for my HR, problen is from what I have researched 15" Weld wheels will not fit?
Anyone have any experience with installing 15" Weld Wheel on a HR over some decent disc brakes??
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
Talk to Southern Chassis Works about their replacement front crossmembers. They told me I could have BA rotors on my HK but needed to use 15" rims. |
Thanks HK I'll keep those guys in mind and if no luck will give them a call.
I'm really just looking for a HR brake upgrake kit that works with 15" Weld wheels, dont want to change crossmenber etc.
Thanks for your input.
HQ stubs, rotors & calipers with early pattern fitted to the rotors will suit. Great bang for buck on an early Holden.
utility8
Fastlane
Holden Forums
