RussVRute Offline
#1 Posted : Tuesday, 17 May 2005 7:09:02 AM(UTC)
RussVRute
G'day All,
Now I have my premier front end on the tonner, I was thinking of getting rid of the bull bar and putting a normal bumper on, I think the 4 poster is a bit garish and austentatious, and being a tonner with the HQ front I basically took the easy route and put an HQ Premier front on, so I need to know which bumper? did the HQ have a different bumper for the premier?, I know the later models had a different one but I've only seen one type on HQ's, and will the later model (HX -WB I think ?)premier bumpers fit?(the ones with the rubber strip on them, they look very nice)Any help will be appreciated. Thanks.
Russ
#2 Posted : Tuesday, 17 May 2005 7:50:50 AM(UTC)
All HQ are the same. The later ones fit but will look silly as the HQ has a close fit bar that recesses into the guards and nosecone, whereas the HJ-HZ bar sits proud of the guards and nosecone.
#3 Posted : Tuesday, 17 May 2005 8:10:29 AM(UTC)
Hi Guys.
I might be stating the obvious here, but the HQ 1 tonner front b/bar is different to the normal Belmont, Kingswood, Premier type.
Dr Terry.
#4 Posted : Tuesday, 17 May 2005 9:21:44 AM(UTC)
Hi Russ,
Did you get the headlight cups off Peter?
All HQ "sedan" (or non tonner) front bars are the same. The 73/74 models had orange indicator lenses whereas the 71/72 models had white indicator lenses and the indicators were also the parklights.
#5 Posted : Tuesday, 17 May 2005 4:35:48 PM(UTC)
If you've got the Prem front on it now then you have to use a HQ non-commercial front bar otherwise you won't have any front indicators!
