gtrpu Offline
#1 Posted : Tuesday, 5 May 2015 6:23:29 AM(UTC)
gtrpu
I have a 327 block that I would like to ID. Engine number is 3274***5T07I3H5 (Stamped into the block).
Casting numbers are T14 CONV1 GM8914660 H2660638
Any ideas???????
#2 Posted : Tuesday, 5 May 2015 4:47:01 PM(UTC)
It is a Dandenong HK GTS327 block (if the number stamps are original) from a 3rd (last) batch of early type GTS327 engines. Normally found in approx. October to December 1968 HK GTS327.
gtrpu Offline
#3 Posted : Wednesday, 6 May 2015 5:37:33 AM(UTC)
gtrpu
Thanks for the info...it matches up with what we were told. The stamping seems to be authentic as well.
#4 Posted : Wednesday, 6 May 2015 4:48:19 PM(UTC)
I'd say it is too by the way you have typed one of the characters. If you get me the 3 missing digits i'll see if we can nail the car it came from. If that car is still around the block would be worth really good $ to the car's owner.
gtrpu Offline
#5 Posted : Monday, 11 May 2015 6:35:19 AM(UTC)
gtrpu
Hi Byron. I sent the other numbers to you the other day. Did you have any luck with them?3
