iitsmint Offline
#1 Posted : Tuesday, 11 August 2015 4:34:04 AM(UTC)
iitsmint
Hello all, I am fittings commodore vy steering column to an eh, I'm using all the electicals except the airbag srs system. Does anyone know if the actual air bag and propellant in the horn pad can be removed from the horn pad ?
#2 Posted : Tuesday, 11 August 2015 4:55:09 AM(UTC)
No need to remove as it is a passive device, ie needs power to activate. So if you do not wire it up it will not go off.
Warren
iitsmint Offline
#3 Posted : Tuesday, 11 August 2015 8:17:33 AM(UTC)
iitsmint
